Sigma 18-50 mm F2.8 EX DC lens
robbynaish
Iscritto: 23 Giu 2004
MessaggioInviato: Mar 20 Lug, 2004 7:38 am    Oggetto: Sigma 18-50 mm F2.8 EX DC lens Rispondi con citazione
Nuovissimo Sigma
EX series, large aperture zoom lens designed specifically for use with digital SLR cameras
EX lens series denotes excellence of engineering and new technology.
Compact and lightweight zoom despite large F2.8 aperture.
Excellent correction for various types of aberration provided by one SLD (Special Low Dispersion) glass element and two aspherical lenses.
Super Multi Layer (SML) coating reduces flare and ghosting from which digital cameras tend to suffer.
F2.8 large aperture standard zoom lens designed specially for use with digital SLR cameras.
The characteristics of digital SLR cameras were taken into consideration when designing the lens power layout. The new advanced lens design corrects various aberrations. This lens provides the utmost correction against lateral chromatic aberration which is a serious problem for digital SLR cameras.
This lens is specially coated to get the best color balance whilst cutting down flare and ghost caused by reflections from the digital image sensor and lens. It has excellent correction for vignetting and superior peripheral brightness is ensured.
A Special Low Dispersion (SLD) lens and two aspherical lens elements provide excellent correction for all types of aberrations. The design produces a compact and lightweight, yet robust, construction with an overall length of 84.1mm (3.3in.) and maximum diameter of 74.1mm (2.9in.) and weight of 445g (15.6oz).
This lens has a minimum focusing distance of 28cm (11in.). It is equipped with inner focusing system. The non-rotating front lens element makes the lens suitable for using its petal-type lens hood and circular polarizing filters.
It is an ideal large aperture standard zoom lens for digital SLR cameras featuring APS-C size image sensor.
Sigma 18-50mm F2.8 EX DC lens specifications
Focal length 18 - 50 mm
Minimum aperture F22
Lens construction 15 elements in 13 groups
Angle of view 69.3° - 27.9°
Number of diaphragm blades 7 pieces
Minimum focus distance 28 mm (11 in)
Maximum magnification 1:5
Filter size 67 mm
Hood Petal-type hood
Dimensions (Dia x Len) 74.1 x 84.1 mm (2.9 x 3.3 in)
Weight 445 g (15.6 oz)
Alessandro
paganetor
Iscritto: 18 Gen 2004
MessaggioInviato: Mar 20 Lug, 2004 8:14 am    Oggetto: Rispondi con citazione
non vorrei fare il pignolo, ma questo mi dà l'idea che la lente sia di qualità medio-alta al centro e pietosa ai bordi (che le comunu DSLR non sfruttano).
se la monto su una cam analogica che risultati avrò?
zimboart
Iscritto: 18 Dic 2003
MessaggioInviato: Mar 20 Lug, 2004 8:22 am    Oggetto: Rispondi con citazione
non credo buoni......fermo restando che puo rappresentare una valida alternativa al 18-55 di canon....prezzo permettendo!
altrimenti c'è il 17-35
paganetor
MessaggioInviato: Mar 20 Lug, 2004 8:25 am    Oggetto: Rispondi con citazione
infatti, è quello che pensavo anche io... bisognerebbe vedere qualche scatto... Wink
Andrea Giorgi
supporto tecnico
Iscritto: 13 Dic 2003
MessaggioInviato: Mar 20 Lug, 2004 8:34 am    Oggetto: Rispondi con citazione
...delle belle belle vignettature...
robbynaish
Avrai delle MEGA VIGNETTATURE
Alessandro
paganetor
MessaggioInviato: Mar 20 Lug, 2004 9:06 am    Oggetto: Rispondi con citazione
ecco, appunto! Very Happy
Izutsu
Iscritto: 28 Dic 2003
MessaggioInviato: Mar 20 Lug, 2004 9:33 am    Oggetto: Rispondi con citazione
Non capisco questa strada di Sigma... meglio Tamron che ha reso "telecentrici" i suoi obiettivi piuttosto che Sigma che ne riduce il cerchio d'immagine... i primi andranno bene anche sul formato pieno, i scondi no... e quando si parla di ottiche "EX", ovvero della serie "buona", dispiace un po' buttarle via...
chinchillart
Iscritto: 15 Apr 2004
MessaggioInviato: Mar 20 Lug, 2004 10:02 am    Oggetto: Rispondi con citazione
Uhm, io non farei tanto affidamento al "sigillo" EX, il 20mm f 1,8 che mi piaceva tanto, a confronto con il 18-55 Canon del Kit 300D sembra una ciofeca.. e immagino che in full frame sia peggio..
http://www.pbase.com/jorrit/lenstest
Roberto
Izutsu
MessaggioInviato: Mar 20 Lug, 2004 10:03 am    Oggetto: Rispondi con citazione
Beh, resta sempre la serie buona, quella che costa... e spendere 400 euro per poi ritrovarsi tra 3-4 anni a dover cambiare ottica... non so se mi spiego.
chinchillart
MessaggioInviato: Mar 20 Lug, 2004 10:22 am    Oggetto: Rispondi con citazione
Sono perfettamente d'accordo!
ROb
daffy
Iscritto: 16 Lug 2004
MessaggioInviato: Gio 22 Lug, 2004 9:06 am    Oggetto: Rispondi con citazione
Roberto
ho guardato le foto in quel test. Secondo me il Sigma era fuori fuoco. Appena ho un secondo faccio un test del mio 20mm che e' molto valido vs il 18-55.
Se vuoi continuare il discorso attaccati a questo post: http://www.photo4u.it/viewtopic.php?t=7953
Devis
Devis - www.daffy.it
